Deleted member 21878
i have started tearing apart the front suspension on my car. for those who may not have read any of my previous posts... i bought the car in boxes and mostly apart. only a few things still remained attached to the body/frame.
this week i started on the front suspension. a couple of questions came up.
the PO had bought a number of different parts for the car as he intended to redo the car himself. So as i went thru the boxes i found a number of front suspension parts. Laid them all out on the floor and marked them to see what was missing and what i needed to order. Just finished with the order.
first thing i noticed:
there was a new set of inner lower a-arm bushings in the box. all numbers match what they should. but the old bushings i took out have a wide flange to the outside and the new bushings from Moss do not. Assuming someone has figured out the wide flange is not necc. Thoughts? see pic.
second, the PO must have bought a new swivel pin kit from someone. Not sure who but i did notice a couple of differences from the original. one is that kit came with o-rings in place of the cork ring that goes at the bottom of the swivel pin. again thoughts?
next i also noticed the new swival pins do not use a castle nut at the top of the pin but use a ny-loc nut. again thoughts?
see pic below: other than that the swivel pins look identical.
Thanks
Thanks
