Cain
I'm in the process of taking apart my front suspension to replace bushings, springs, and shocks. I'm working on the passenger side right now and I've got everything apart except the vertical link - I can't detach the tie rod lever from the tie rod and I can't get the ball joint off the top of the vertical link. The vertical link is just dangling there hanging from the steering tie rod. (Yes, the tie rod lever and vertical link are still attached.) It looks to me that these two connections should slide out - i.e., they are not threaded. I've tried the penetrating oil route already - I let it sit for at least two days twice with tapping the oil down into the connection both times.
Any suggestions? I've been around the block with many old rusted bolts, etc. since I've had the car, but this one has me stumped. I don't want to get too violent and damage these parts trying to get them apart. I'm not in a position to get it to the bench and put it in the vice because I can't get it off the tie rod.
TIA
TIA
