Anyone with experience using the poly front suspension bushings from Moss Motors. A set of mine I'm ready to install to an MG-TD (same as MGA and MGB) are a little bit loose when fitting to the suspension "A" arm. They are a snug fit on the mounted pivot but about .020" off when fitting to the "A" arm.
When tightened up they also squeak a bit when the arm is moved. Is this normal and will I hear it later?
Will I notice the lack of a tight fit in the bushing to arm fit?
Thanks, George
Thanks, George
