Hawkscoach
59 BN4 100/6
I was finishing some corrective aluminum welds on the front shroud and want to make sure I don't fill the wrong holes.
1. When the car was raced, someone put the leather strap across the bonnett. there are two holes on each side for the strap "tie down brackets" that i just removed. These holes are about 2" apart on each side.
2. There are also two holes closer to each other, just inside (toward the bonnett) on each side that I presume were for side mirrors? Total of 4 holes each side. If the mirrors used the inside holes, and IF the strap was used, the inside holes (mirror holes) would conflict with the strap holes.
3. If this is correct, should I fill/repair the outside (wider) holes and leave the inside (closer) holes that i presume is for side mirrors? Fill all the holes?
I hope this description is helpful for an answer. if not, i can try to explain better.
I just want to take care of this now so I can finish the front and while I have the machine set up for the aluminum welding.
thanks for any advise and help
Regards,
Doug
Regards,
Doug
