I have been meaning to post this issue but havent got around to it. A while back I had to change my front passenger side shock due to the arm being worn out at the fulcrum point and allowing that side to have a lot of play. Luckly I had a local MG parts dealer where I was able to get another replacement shock off the shelf yet this was a used one from another Midget. The shock looked fine and didnt leak and I walked out with it for $40. I put it on with no issues but notice now when I turn right and apply the brakes I get a vibration / rubbing sound. I took the front wheel off to look for metal shavings or a contact point but cant see anything except the brake rotor shield slightly pushed in toward the rotor. My guess is the arm is possibly longer or something and is binding in some way. It only happens when I turn to the right with the brakes applied. I didnt have any issues before replacing the shock. Any ideas on this?
