front/rear coil spring diamaters.
skikir
does any one have a set of springs out that can measure the inner and outer diameters of the front and rears. I have a a spring spacer for the rear that I would like to use on the front (don't ask!)
I have a set out w/ spacers. I'll measure
tomorrow in daylight and post the dims.
Tin
Here is the photo-
The coil springs are the same diameter front and rear. They use different mounting rings for some reason.
hope this helps.
d
How tall are the rear springs? Are they the stock hieght, or the uprated type?
