Cottontop
Background - Several years ago after several miles of "spirited" Interstate driving (at speeds higher than I want to admit to) I pulled of the I'state and as I stopped at the stop sign at the end of the ramp, I heard an ominus, brassy, "ker-lunk!"
I knew immediately what it was. When I went to look, sure enough, my right front knock-off was lying on the pavement next to the tire. The fine brass threads had been pulled out by the spinning of the wheel on the braked steel splined hub.
I called home and my wife brought me a new knock-off. I have driven "gingerly" since then.
Logic tells me that the newer style course threads should be stronger than my fine threads. Logic also tells me that if I installed brand new front splined hubs along with my new chrome wire wheels that the wheel should NOT spin on the hub and I should not be relying on the knock-off to keep the wheel from spinning on the hub.
Question A - Will new fine thread front hubs with new wheels prevent a recurrence of what happened AND/OR as long as I am buying new hubs, should I go ahead and buy the course thread hubs ?
Question B - IF the answer is to go ahead and buy new course threads, Will the course thread hubs FIT on my fine thread hub axles or do I need to (try to) buy new axles to accomodate the course thread hubs ? I know that the bearings are different.
I have a V8-Automatic car and used to frequently spin the wheels on the rear splined hubs (it would just unscrew the knock-offs). When I re-did the car 10 years ago, I installed new splined hubs and haven't loosened one since. Inspection shows that the rear splines are in VERY good shape with no perceptible damage.
What are your recommendations ?
Thanks,
Tim
Thanks,
Tim
Hi Guest!
