front hub options...
6969ronin6969
Curious what are the options out there for the front hub for a TR3. I've read about Southwick aluminum front hubs. Are those still available? Any other options out there, besides stock of course.
Thanks,
Eric
TR3driver
Great Pumpkin - R.I.P
You could ask, but the Southwick hubs were a very limited production run, organized by the late "uncle jack" Drews. With only 25 sets made back in 2005 (AFAIK), I doubt there are any left on the shelf.
"To order, call Southwick Machine and Design, 309-949-2868."
I'll add that first one I tried did not run true. Probably just a burr under one of the bearing races (but why bother pre-installing the bearing races if you're not going to do it right?) But I'd had them on the shelf for several years, so I didn't try to contact Southwick to complain.
Revington probably has something, check their web site.
Another option is to reinforce the original type hubs. Here's a photo courtesy Jack Brooks.
6969ronin6969
Thanks Randall. I had not heard of reinforcing the stock hubs. Any more info on that available?
I did remember to check out Revingtons and Racetorations after first posting the original question. Both had some options. I've sent Revingtons some questions to get more details.
If you think of something else, let me know.
Thanks again,
Eric
6969ronin6969
After further searching, Rimmer Bros. also offers an alloy hub and Good Parts does as well.
So the good news is there are some options out there. Here are links to each place:
USA:
Good Parts
This kit includes bearings.
UK:
Revington
This is the hub only, bearings are separate.
Racetorations
Multiple options here, some including beefed up stub axles as well.
Rimmer Brothers
I am assuming hub only, bearings separate.
So does anyone have any experience with any of these options? Best I can tell, the Revington setup might be the least expensive, even after buying the bearings extra. I don't know what type of bearings they are using though. I have asked. On the plus side, it might also be the lightest weight, and reducing unsprung, rotating mass is always good. Revington has a good reputation, and I trust they haven’t reduced it to the point of being prone to failure.
Racetorations and Good Parts seem to offer beefier bearings, but are a decent amount more expensive. Any thoughts on if the extra beef is worth the extra costs.
Thanks,
Eric
TR3driver
Basically they drill a hole in the hub face, directly in line with the bolts that hold the brake disc to the hub. Then run a long tap through the existing threads and tap the new holes. The spacer is cut to length so it is tight in the space available (has to be rapped with a hammer to install), then a long bolt is run through the brake disc, spacer and into the hub face. I believe there is a more complete write-up in one of Kas Kastner's books (but don't recall which one offhand). (BTW, Kas says this mod works well.)
Whether the oversize bearings are worth it probably depends on how hard you plan to drive, and how far. Lots of problems show up on the race track, that you'll never see on the street. I stay on the street (except for the occasional autocross) and have never had a problem with the stock bearings.
R TR2/3/3A front hub seal options Triumph 9
Carlbanan56 MGB Front hub MG 4
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
A BN7 Front Hub Stud Nuts Austin Healey 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Front Hub and Felt Seal Triumph 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
K TR2/3/3A Front hub oil seal Felt? Triumph 1
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
aero3113 Front Hub Inner Bearing Seal Austin Healey 7
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
Jeepster Front hub replacement. Austin Healey 34
Bob_Spidell Securing Front Hub Bolts Austin Healey 8
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
C Front Hub Castle Nut Austin Healey 8
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
R BJ7 front hub shim question Austin Healey 18
catfood Removing front hub Austin Healey 6
RAC68 Calculating Front Hub End-Play Austin Healey 32
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
bertl Front Hub Spacer Kit Triumph 1
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
BillD Front hub puller Spridgets 21
H front hub removal Austin Healey 37
S Spitfire Question on front Hub for a triumph Spitfire. Triumph 4
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
Willie_P TR 3/4 Front Hub Install - question Triumph 15
J Front hub mystery Austin Healey 0
britndablood To install or not to install Front hub spacer Austin Healey 8
Lon_S What hub puller tool works well for the front hub? Spridgets 2
TR4nut Front Hub Felt Seal - Old vs New Triumph 15
D Need a front hub Austin Healey 1
S Front Hub Replacement Austin Healey 7
G Front hub Spridgets 2
TonyPanchot tork settings for 1997 front hub Jaguar 1
TR3driver Front hub balance problem Triumph 17
M Front hub worn out Spridgets 6
Monark192 MGB-GT 67 GT front hub removal MG 10
drooartz Front hub/brake question Spridgets 12
Jim_Gruber Castle Nut on Front Wheel Hub Spridgets 6
B TR2/3/3A TR3 front bearing/hub advice needed Triumph 6
19_again front hub removal MG 3
C BT7 Front Hub Removal Austin Healey 4
