Branson,
Having recently assembled my front clip here goes.
each fender is attached from inside the footwell with 4 fine thread bolts,flat washer and lock washer. 3 just inside the door running in a straight line top to bottom and one near the front of the foot well.
On the outside there is one bolt where the top of the fender meets the top of the cowl, you need to reach into the firewall to put in this bolt.
There is also a screw that goes into a pre welded nut at the rear of the fender, it attaches below the rain gutter along the top of the fire wall. Make sure the fender is below the gutter not on top. This takes a fine thread large head screw, flat washer and lock washer.
Each fender attaches to the front cowl, 3 underneath on each side and two on the top visible from top of cowl.
You now will have the clip all together. The cowl should fit snuggly into the front frame where there are 3 bolts on the upright rails and 4 bolts on the bottom plate.
That is all she wrote.
Mark
