G
I just purchased a 76 MG Midget and the caster/camber look off on the front wheels. When looking from the front of the car both front wheels are further away from the car on the bottom of the wheel than at the top of the wheel. The toe-in looks fine. Shouldn't the tires be almost straight up and down when looking at the tires from the front of the car? I looked at the front suspension and it appears that the previous owner replaced the front springs and lower control arm bushings. Can most repair shops that align front ends align a MG Midget? Can it be done by me? Are there shims used (like on old Fords) to adjust the caster & camber? Any help you can provide would be helpful. I don't want to wear the tires. Thanks.
Hi Guest!
