PatGalvin
Hello All
Has anyone used the uprated front coil springs sold by TSI? I purchased a set of these springs for my 59 TR3A. They are an inch shorter than the factory springs and I assume that they are also a little firmer. I installed one the other day without the aluminum spacer and it seems awful short. With suspension at full extent of lower travel and spring fully inserted into shock tower, the spring actually does not completely seat in bottom of pan (lower suspension travel bumper not yet installed). When I observed this, I figured it might be problematic. So, a couple questions for the brain trust.
1) Has anyone used these and can share impressions? I know stiffer springs are not alway better.
2) Did you install with aluminum spacer? I'll measure spacer when I get home - I think it probably adds an inch to spring length.
I did contact Ted at TSI and he said he's been selling them for 30 years (but apparently, not so much for TR3s, mostly for TR4A and TR6).
Thanks in advance for any thoughts. Goal for this is to improve handling for fun road driving - not racing.
Pat
Pat
Hi Guest!
