TR5/TR250 Front carb spitting fuel out overflow
tinman58
I was at our British car club meeting this morning. One of our members has just did a start up on a rebuilt motor. Ran well for the 20 minute breakin. The next morning went to start the engine and fuel was “squinting “ out the over flow tube. Long story short he has taken everything apart and replaced just about everything he can think of. We asked all the normal questions, to no avail. Any ideas?
Rebuilt original carbs.
TR3driver
Great Pumpkin - R.I.P
So the float and float valve in that carb have been replaced with new since the problem started? My next steps would be to double-check fuel pressure and look for any kind of mechanical problem stopping the float from closing the valve. There isn't much else it can be.
tinman58
tinman58
Taken apart the needle valve replaced with the old one that worked. He did say there was a little bit of crud on the first go round. He did swap out the fuel pump with another one. No change, I believe he next thing was to put in a fuel pressure regulator. He has removed the carb and tried different things "Ten times". He is finishing up on a very nice TR 250 Restoration.
TR3driver
My money's on another bit of crud.
Note that fuel pressure regulators have a minimum forward pressure drop ... if the pressure is already correct than adding a regulator is going to cause problems rather than fix them.
Geo Hahn
Or if it is a ZS carb - verifying that there is no fuel inside the float and that the float height is correctly set.
ZS or SU? Either way the fuel valve is not cutting off. I'd had some ones that apparently angle inside (I got censored for using another word) and won't cut off fuel. Dry they would work fine.
Marv
tinman58
tinman58
Thanks all!
I will call him and have him check it again.
Rhodyspit75
I worked on an AH 3000 last year and occasionally one of the carbs would pour fuel out of the overflow tube. Since it didn’t happen all the time we all thought that it was needle valve related. It couldn’t be the float because the carbs had been “professionally “ rebuilt and if the float had fuel in it it would happen all the time. After many attempts to solve the problem one of the guys working on it said let’s pull the float we’ve got nothing to lose. The float had never been replaced during the rebuild and had a hairline crack in it. It had gas in it. We still can’t figure out why it would work sometimes and overflow others. Did you check the float?
TR3driver
Had a similar problem with an American V8 once. Except instead of a hairline crack, it had Nitrophyl (plastic foam) floats (as I think the TR250 carbs do). The old floats were not resistant enough to ethanol (or might have been MTBE then) and had absorbed fuel until they were just a bit too heavy. Most of the time, they would still work enough to keep fuel inside. But when things got hot under the hood (like pulling a grade), fuel would start pouring out the top of the carb.
Hot fuel is less dense, so the float has to displace more of it to hold the valve shut. My theory is that is why it worked sometimes and not others.
I replaced them once, the new floats worked for a few weeks then the problem came back. Apparently, at that time, even new floats weren't ethanol resistant. After much searching, I finally found some brass floats that solved the problem permanently.
I'm assuming that, by now, no one is selling non-resistant floats in the US. That's why I mentioned replacing the float first thing.
pdplot
Several years ago, I had an overflowing from front carb. I hit the float bowl a couple of times with a wooden hammer handle and it stopped immediately and I've had no trouble since.
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
T TR2/3/3A front carb bellcrank Triumph 4
M TR6 TR6 Gas Leak From Front Carb Triumph 5
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
BillyB62 TR2/3/3A Front Float Cover Lid for TR3 H6 Carb Triumph 10
B Front carb choke linkage pin Triumph 5
Shinsen774 Front SU Carb Leak - Advice? MG 19
jerrybny Front Zenith carb overflowing Triumph 20
RedTR3 TR2/3/3A TR3 Front Carb Running Rich Triumph 13
C Front Carb Fuel Level Too High, Rear Too Low Triumph 8
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 6
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
