Front brakes won't release after disc brake conversion
Ohiobugeye
Hello All, It's been a while since I have used B.C.F. Being I have little knowledge to pass on I'm mainly a member asking questions. I have a 1959 Bugeye with 1275, rib case, elect ignition and a webber carb. I recently converted the front brakes over to disc. My problem is that the front brakes won't fully release. I have been able to drive the car short distances but the brakes are dragging enough that the car will only go about 40 mph with the pedal to the floor. Again just after a short distance the brakes a really hot. I bought a complete disc system off of a 1972 Midget from ebay and replaced the Calipers, rotors and pads, and a new 3/4 " master cylinder along with new rubber brake lines with new parts from Vic. Brit. I was to locally to replace the rubber lines with stainless steel braided lines because the rubber lines were probably collapsing from the pressure increase.The rear brakes are fine but the new front disc brakes still won't release. The entire hydraulic system has been bled many times. If the car sets overnight the car will roll by hand but once the brakes are applied they are locked up again. Any and all suggestions will be appreciated. Thanks< Don Davidson aka the ohiobugeye.
dklawson
I don't understand the quoted sentence. What were you trying to say?
Old rubber lines may collapse on the inside from years of fluid exposure and internal swelling. Such hoses have been known to act like check valves where fluid makes it to the wheel cylinder/caliper but cannot get back to the brake reservoir. However... you said you replaced the lines. Increased brake fluid pressure will not make new lines collapse, it will make them "balloon".
If the front brakes are locking/dragging after a short drive, try cracking the bleed nipple for one of the front wheels immediately after you get home. Note if fluid jets out of the bleed nipple or not.
You say you transplanted a complete system from a '72. Are you confident that the MC pushrod is fully retracted when you release the pedal?
histerical
ditto. make sure the piston is fully retracting in the master. there should be 'some' free-play there or the piston will not travel in far enough to uncover the return port and the line will remain pressurized. driving around with a dragging brake can over-heat the bearings or warp the rotor.
Joe Schlosser
Agree with others, 3/4 inch pushrods are different length (shorter) than the 7/8 inch. If you are using the 7/8 pushrod then the MC will not return fully. good pics on Gerards site.
hcallaway
On another track, I had some issues with one side on my disc brake conversion where the bearings were not fully seating on the spindle due to the taper on the bearing and taper on the shaft. The disc's would barely spin and the disc was not centered between the pads. Just something to check.
Ohiobugeye
Ohiobugeye
Thanks for the quick reply's To answer dkdawsons question on the clarity of the above mentioned sentence it should have read "I was told locally to replace the rubber lines". A local mechanic suggested that I replace the rubber lines.
Great info on the push rods , I'll check it out. The article from Gerardsgarage.com Thanks to all, Don
dklawson
Thanks for the clarification.
To restate what I mentioned earlier.... OLD rubber hoses may swell inward turning the brake hoses into check valves. NEW rubber hoses won't do that. The stainless overbraid hoses won't do that... ever. However, if you installed new rubber lines already there is NO reason to replace them. They won't close off internally due to "higher pressure" as you were told.
Ohiobugeye
Ohiobugeye
Problem Solved ! You guys were right on the money.I readjusted the nut on the control rod to shorten the length by about 7/16" and the pads were able to retract. I drove around the neighborhood testing the brakes and after a few minor adjustments the brakes are working fine. The clutch has the same 7/8" control rod but it seem to be working fine. As always , the advice from the Forum solved my problem. I was able to buy a 3/4" control rod from a 65 Midget and I will install it when it arrives this weekend. Thank You, One and all. Don Davidson
Gerard
For those who may be unaware, along with supplying the best 3/4" master cylinder conversion available anywhere, I also have new manufactured correct length cad plated pushrods.
John_Mc TR6 Front brakes won't release Triumph 20
ncbugeye Front wheels won't spin, dsic brakes binding? Spridgets 13
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
K TR2/3/3A Sticking front brakes? Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
C 100-6 front drum brakes? Austin Healey 36
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
P Front drum brakes - fluid lines Austin Healey 12
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
trrdster2000 Post-War Other Front brakes on the Roadster Triumph 5
R BJ8 Front Brakes drag some Austin Healey 9
T TR2/3/3A TR3A front brakes Triumph 2
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
M Stuck front brakes? Spridgets 8
M Front brakes are sticking Spridgets 33
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Stewart Dragging front brakes MG 7
B front disc brakes- 66 sprite Spridgets 8
RickB Front brakes seizing - what's with that? Spridgets 23
M Slight bind in front brakes Spridgets 7
R Front Brakes... Spridgets 7
sparkydave Dragging front brakes Spridgets 4
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
T Time to redo all my brakes and front suspension... Triumph 14
S TR2/3/3A tr3 front brakes hoses Triumph 9
drooartz Installing front suspension/brakes - review Spridgets 1
zschicago my first Healey and questions about front brakes Austin Healey 10
v8mgbal front brakes Spridgets 9
M Difference between MK IX and XK 150 Front Brakes? Jaguar 6
Brosky Front Suspension & Brakes -Done Triumph 5
N TR6 Clip wires on front brakes for TR6 Triumph 9
eejay56 BMW 320i front brakes locked up Other Cars 8
1 front brakes Spridgets 3
19_again leak front brakes MG 6
M front brakes Spridgets 12
M front brakes Austin Healey 3
jmwuva05 Front drum brakes. Spridgets 2
zimmy front disk brakes Spridgets 9
T TR4/4A Early TR4 - Front Brakes Triumph 3
zimmy front brakes and calipers Spridgets 3
R TR6 TR6 front brakes Jack Drew Triumph 13
