A few weeks ago I had the little problem of the short out and fire in the wire leading from my electronic ignition (or to it). Many of you were kind to offer advice such as "put the points back in". I could not locate them, so I replaced the EI with a new one. Problem solved, works just fine. New problem. On a recent trip I came to a stop sign. Pedal right to the floor. No brakes at all. just had the front brakes redone and the hoses replaced. I checked the fluid level.....none was present.
I bought some new fluid, and filled the little tank, expecting to find the source of the leak when I steped on the pedal. Well, pedal still goes to the floor, no fluid is leaking out, and I don't know where to go next. Help!
