Deleted member 20523
Upper control arm adjusters almost complete.
Really impressive stuff. What is the owner going to do with the car? Is it an exercise in concept, design and fabrication? Where money is not a factor? My brother in law was the head fabricator for Newman Hass. He has built a carbon fiber Honda powered Nobel just because someone has an idea. Really cool to see all the work you guys have done.
Spectacular!!!!! Eye Candy for the gear head. Looks like you have great clearance with the headers you are using. Will the rest of the exhaust be an issue with how low the car will sit or will you run it above the pan or level with the tubular chassis?
Forgive my ignorance but what is an LS engine?
Question: On the upper A-arms where the Rose joint threads into the aluminum... is there a steel sleeve installed in there? If not, what thread size/tpi are used?
Chevy V8
