jjbunn
I was amused to find that the horn on my TR6 is a French Horn. It even has a metric (10mm) bolt that fits it to the bracket.
I had to take it apart as it wasn't working. At some point there had been water ingress, and so there was some rust. After cleaning that up and lubricating everything, and a bit of emery cloth on the points, it worked very well. In fact, when I tried it on the bench I almost jumped out of my skin.
It's a "grave" (low) note horn. The other horn is missing: I assume this would have been a high note horn. The wires to it were snipped bare off ... so I joined them and will make do with the single horn, which is quite loud enough.
In fact, to get the whole system to work, I had to remove the steering wheel (a major PITA), solder a new wire onto the brass contact ring piece (the old one had become detached, and was in any case too short) and thread it through the steering wheel cable tray ... some WD40 helped.
The horn looks original ... but maybe not. What brand of horn was usually fitted to TR6s - ClearHooters?
