Frame Measurements
BOBBYR
Good morning Guys ,
I hope everyone is doing well . In the last year I have put together , what I think , is a pretty good plan for a full frame off restoration . My Healey is a tittled 1965 BJ8 that was actually built in November of 1964 . In the past I have tried to acquire as much information on the proper frame measurements , always running into the same old problem . It seems that there is very little published prints or drawings for BJ8s . If anybody is aware of a straight forward print , please let me know how I can get a copy . I hope you all have a great day .
Bobby R
Keoke
HI:
There should be a complete frame drawing with dimensions in the factory manual.
Keoke
Additionally:I think we need to clarify.
That there is not a conventional bolt on body for the big Healey cars.
One cannot simply remove [unbolt] the frame from the body.
During a ground up restoration a bare composite chassis is generally the lowest level of disassembly.
To illustrate what Keoke is saying, this is BN6L/942 reduced to zero (0) remaining bolt-on components; not a single fastener (bolt, screw or clip) on the superstructure anywhere.
Same method of construction through the BJ8 models.
To go any further would require cutting torches and/or cold chisels.
Keoke
Thanks much Randy :encouragement:
Is is possible to straighten the frame on a Big Healey? My BJ8 has a little body sag on the driver's side; wondering if a frame shop could put it on a straightening rig.
Keoke
Yes if all the involved metal is good.
Alternately it may require ;
1 Frame parts replacement with new bits.
2 Stiffening members added to the existing frame.
Yes. I pasted mine to the side of a mountain in Woodside, California, following an AHC?Pacific Centre officer's election picnic, and LeDue & Ahonen (sp?) frame shop in San Francisco pulled the RH (LH?) frame rail back into position. Tough to remember now, but I'm thinking that one side__or the other__was "up" about 1-1/2" @ the front bumper mounts, and I seem to think "the kink" was about halfway between the engine mount pedestal and toeboard.
Another friend, Layne Perkins (and which may or may not be one of the Healeys that Marvin here worked on) was hit the day after he bought it in Lafayette, Louisiana. Hit hard from behind, and jammed him into the car in front too. That rolling chassis was stretched/straightened by a shop near the corner of Louisiana Avenue and the Breaux Bridge Highway (Jim/healey blue) probably knows, or remembers the name of the shop.
Just like any process that we're familiar with ourselves, to the frame-shop guys, straightening the car back out is no big deal; they work off the datum points as laid out in the back of our shop manuals. The Complete Official Austin Healey, by Robert Bentley , Section R (tried to upload a pdf of the pages, but I'm not that smart...).
Thanks, Randy (I do have the Bentley manual, grease-stained and dog-eared). My concern would be the 'superstructure;' and if if would be difficult to bend the 'chassis' with that superstructure resisting (of course, the superstructure didn't resist the bending in the other direction too well).
CLEAH
Bob, as Keoke suggests, it seems likely that it would require a new sill and /or outriggers. Unless it was an otherwise sound car that got tweaked in an accident, putting weak metal on a frame straightener seems like it will not fundamentally fix the problem, or at least not for long.
RAC68 Top Frame platform location measurements Austin Healey 0
BOBBYR BJ8 frame measurements Austin Healey 4
T Frame Measurements BN-1 Austin Healey 3
F GT6 Happy Ending - Missing GT6 Frame Measurements Triumph 0
F GT6 Call for help...missing GT6 frame measurements! Triumph 16
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
C TR2/3/3A Frame repair and value Triumph 2
J TR6 Repadding TR6 frame Triumph 0
B TR6 TR6 convertible top frame Triumph 0
zoohow BN4 Top Frame Installation Austin Healey 1
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
S TR2/3/3A Placing the differential on the frame Triumph 4
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
H TR4/4A Advise asked on TR 4 a frame collision/issue Triumph 20
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
S TR2/3/3A Frame repair. Triumph 47
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
ActionJackson Spitfire Frame Triumph 0
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R TR6 Frame repaired? Triumph 6
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
7 Wedge Removing sunroof frame Triumph 5
Rut TR4/4A 4a frame modification Triumph 6
D General TR Frame repair - recommendations for NJ area Triumph 3
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
D TR2/3/3A Windshield frame fitting. Triumph 2
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
JamesD BJ8 Top Frame Bumpers Austin Healey 12
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
Healey Nut Seat Base Frame Position Austin Healey 4
P TR6 TR6 Frame Stiffener Triumph 4
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
C 100/6 BN4 Soft Top Frame Austin Healey 16
B Bent frame rails near BE front end Spridgets 2
F TR2/3/3A Bumper frame brackets Triumph 10
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
F TR2/3/3A Bumper bracket to frame question Triumph 7
P For Sale MG TF Ash Frame parts for sale MG Classifieds 0
D BJ7 Hood frame mounting plate Austin Healey 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
dbenichou289 TR2/3/3A top frame bracket Triumph 7
J Painting a Frame and Substructure Austin Healey 12
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
