In a recent vintage race my 1500 Kent pre-crossflow engine suddenly dropped from firing on four cylinders to two. Cylinders one and four are firing, two and three are not. Over a period of several days I have tried the following:
- Replaced the entire ignition system incl. distributor body, points, condenser, coil, high tension and low tension wires and spark plugs.
- Replaced the head gasket.
- Performed compression and leak-down tests with all reading within acceptable limits.
- Verified cam timing.
- Verified valve operation, lift and lash.
- checked intake valve stem seals.
- Tested an alternate intake manifold / carburetor system.
None of these actions has any effect on getting cylinders two and three to fire.
Does anyone on this forum have any additional input or theories to help resolve this issue?
Thank you
Thank you
Hi Guest!
