Wrong.... That is about where the jet should be before starting the adjustments, which is then 12 flats down.I always thought the jet height was supposed to be level with the bridge???
So what would the correct jet height below the bridge be for the SU's?Wrong.... That is about where the jet should be before starting the adjustments, which is then 12 flats down.
Charley
I hope you have access to the procedure for adjusting the carbs. There is the 1. all of the way up starting point for the jet. Then there is 2. the 12 flats down beginning point. Then there is 3. the final level. This level will depend on your individual car.So what would the correct jet height below the bridge be for the SU's?
OK. I see that the level depends on the individual car. I suppose what caused confusion for me is that I have seen on various forums where people have stated a specific point below the bridge where the jet should be.I hope you have access to the procedure for adjusting the carbs. There is the 1. all of the way up starting point for the jet. Then there is 2. the 12 flats down beginning point. Then there is 3. the final level. This level will depend on your individual car.
Charley
The condition of the individual car to me would I believe, include float levels, carb throttle shaft condition(air leak), valve adjustment, timing, height the needle is mounted in the piston and I am sure others.OK. I see that the level depends on the individual car. I suppose what caused confusion for me is that I have seen on various forums where people have stated a specific point below the bridge where the jet should be.
