For debate: Replace or rebuild a master clyinder
Re: For debate: Replace or rebuild a master clyind
70herald said:
PeterK said:
rotoflex said:
They don't make them like they used to,
Right on brother! Same applies to most things. Lots of the new repro stuff is disposable, produced for the lowest bid;
If I needed a new master cylinder, I would order this:
Wilwood master cylinder
It should swap in 1:1 and is available in versions with remote reservoirs. Just need to add a clevis. Wilwood is high quality part and will be better quality than allot of the junk some of the suppliers are trying to pass off on us.
Agree. That's the cylinder that I am using for the clutch on my 4A (with the HVDA kit). But the reservoir is smaller than a 4A master and the cap is plastic. Girling cap won't fit on it. I used to use Wilwood calipers on my race car an is good quality.
I'm using a TR6 setup with booster for brakes on the 4A.
