Foamy silicone fluid in master cylinder
I like that idea. Maybe that's what it is. Thanks!
TR3driver said:
Something else wrong ... even if the fluid did form air bubbles (which I don't believe), they would just push fluid back through the MC into the reservoir, rather than making the brakes drag. You must of had a misadjusted MC, or a sticking pedal, or a broken/weak pedal return spring, or something.
Actually, come to think of it, my brake master cylinder did have a bleed-back valve problem that didn't let the front brakes depressurize, and I flushed the DOT 5 silicone brake fluid out of the system when I rebuilt that master cylinder. The fine bubbles increased over time, however, and I stand by that observation. I've never read that silicone brake fluid is long lasting, but I have read many times over the years that it does absorb air. Many manufacturers now do not recommend DOT 5 brake fluid, including Porsche. The attachments don't bear on this subject. But, yes, the brake master cylinder problem I corrected also explained the dragging brakes I had, but not the soft pedal or increasing air bubbles when the brakes were hot. (And, no, I don't believe I ever got my brakes up to the 500 deg. F service rating for DOT 5 fluid.)
I originally went to DOT 5 fluid because of its high temperature performance. I routinely got my brakes very hot in autocrosses and other races back then, especially since my Midget didn't have vented disks. I didn't like the fade at all with LMA brake fluid, but after the later problems with DOT 5 I decided to live with the problem, especially since I didn't like the soft brake pedal that the DOT 5 fluid gave me.
On the subject of new master and wheel cylinders with dry components, just take extra time bleeding the brakes. I've used a Gunson EZ-bleed for 20 years on my European and British cars, and it works very well for pushing bubbles out. In fact, I bought it specifically to help bleed the Midget's brakes after putting in the DOT 5 fluid, and spending hours hand pumping and hand bleeding, and still not getting the bubbles out of the DOT 5. The EZ-Bleed allowed me to get the bubbles out of the system. If you're rebuilding your own brake components, use a hydraulic seal lubricant. The stuff I have is a synthetic lubricant suitable for natural or butyl rubbers, but brake fluid should work just as well (except for that "squeeky" feeling on your fingers).
Scott
One of the attributes of silicone, being that it does NOT absorb water is long life. It should outlast the tires, several times over.
Sounds like your master cylinder "tip-off" valve may be a problem.
As far as heat resistance Lucas and Ford both make a superhigh temperature resistant fluid. Only thing is it eats paint and is hygroscopic. So it has a limited life span. And the longer it is in the system the more moisture absorbe. The more moisture absorbed the lower the temperature resistance.
