I'm slowly getting my 5 speed kit in motion and a question arose because I'm going to trim off the lip on the rear edge of the flywheel as part of the lightening process I'm going with.
The flywheel is marked on the lip with a scribed line marking where the flywheel should be aligned with the #4 and # 1 connecting rods when installed on the end of the crank. I'll rescribe the line because it will be removed during lightening. My question is, why would the manual require this alignment unless the crank and flywheel were balanced as a unit when manufactured? Does anyone know if such a sophistocated procedure was done? And last, if I have the machine shop balance the flywheel with the new clutch housing on it, does it make any difference how I install it with regard to alignment with the rods.
When I had a career, I dynamically balanced helicopter rotating parts as routine procedures. I understand about dynamic banance, harmonics etc. and this isn't rocket science but I'm no expert on automotive voodo. When I built the engine up I remember doing the alignment but now I can't really see a reason for maintaining it. In fact, since I am certainly fiddling with the original balance of the flywheel, and installing a diaphram type clutch housing it seems pointless to align it this way any longer. Any thoughts?
