jjbunn
The more I use the Haynes manual as a guide for my GT, the more I despair - it glosses over so much detail. Here is an imaginary extract, which hopefully illustrates my point.
Flupple - Removal, Repair and Replacement
Removal:
1) Get on your back under the vehicle and locate the sturnal nipple flange
2) Using a 3/4" deep socket wrench, rotate the nipple through 15 degrees, taking care not to dislodge the carpal conundrum.
3) Apply the hot tip of a blowtorch to your forearm, accidentally
4) Bang your head on the passenger floorpan as you flinch in agony from the burn
5) Swear loudly as the oil pan disgorges its contents on your left shoe
6) Force hand down into underpants to remove ants which have crawled up trouser leg
7) Prying the flange with a breaker bar, apply 40 ft lbs of torque to the copulating clinch bolt
8) Take care to remove the cotter pin from the orifice and discard it
9) Extract the flupple from the reciprocating bung and place it in a clean jam jar containing dirty oil
Repair:
1) Examine the flupple for pitting, scratching, scoring, smell, and impertinence. Discard accordingly.
2) If the flupple is in good condition, kiss it
3) Otherwise, dip the flupple in Royal Acid until it smokes. Place an ashtray nearby.
4) Once the flupple is clean, rub it over with Lush Durn-It Body Lotion
Replacement:
1) Replacement is the reverse of removal, except
2) It never fits
/ubbthreads/images/graemlins/blush.gif
Minor adjustment was needed. Please watch the language, even if the spelling is different. Thanks.
Steve
Removal:
Repair:
Replacement:
2) It never fits
Steve
Hi Guest!
