General TR Fluid Film Rust and Corrosion Inhibitor
DavidApp
I was watching a You tube video of a small mechanics shop in NY. He was talking about the need to do rust inhibition in NY.
He said he used Fluid Film on his customers cars and trucks with good results. It can be sprayed into closed compartments easily.
Has anyone here used it or have any thoughts on it.
Was thinking it may be worth spraying into the sill panels and other areas as I finish my build.
David
Alfred E. Neuman
David, you could also look into a bicycle product called J.P. Wiegles Frame Saver. It's a wax dissolved in a solvent that comes in an aerosol can. Straw tip lets you spray it inside the tiniest of holes. It's meant to protect steel bicycle frames from rusting on the inside of the tubes. Spray it down the down tube, bottom bracket, head tube, and seat tube when they're open before you build the frame up, spray it into the welding vent holes on the seat and chain stays and you'll never - EVER - rust the frame.
I've always thought it would be good for spot applications on LBCs in places like rocker panel cavities and such. Kind of like Wayoil but in a much more controlled manner.
https://www.amazon.com/Weigles-Bicycle-Frame-Saver-Inhibitor/dp/B0012GO58Y
Rut
David,
Ive used Fluid Film, Boeshield and Corrosion X on boats that are kept in saltwater on the Alabama gulf coast and the Corrision X did the best for me. I owned a Yamaha 200 hp Saltwater Series outboard that I sprayed after I bought it and it looked new when I sold it almost 20 years later. For inside frames or enclosed cavities on LBCs I’ve used Eastwood internal frame coating with good success and there’s always Waxoyl which has a solid reputation.
Rut
DavidApp
Thanks for the other products.
Thought that now would be a good time to get into all the hidden places.
David
Geo Hahn
I use Fluid Film extensively. They also sell a 30" flexible wand that throws a wide spray.
I mainly use it in the sills -- works fine but I live in the desert so probably not a definitive testament.
Got_All_4
Anything is better then nothing. Need something to seep into the seams to displace moisture. I'm with the wax products. They don't dry up like the oil based products. Fluid Film is only good for cavities and not under the car where it washes off in no time. You want something to seep/run into seams and then set up. The wax based products skin over and and keep every thing underneath soft.
DavidApp
Got a couple of cans from one of the big box stores.
Spraying it into the sills, under the spare tire compartment, the cavities in the dog legs and the rear section of the front wings.
Will let you know how it does in 20 years. Anything must be better than what it had from the factory.
David
DavidApp
I will be almost 90 so I may be a bit slow with the results.
Probable trying to get my windows 30 machine to work like I want it to.
David
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
P Subaru fluid leak Other Cars 9
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C MGA Shock fluid MG 13
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
longbridgehealey Clutch fluid Spridgets 7
K TR2/3/3A Steering box fluid again.... Triumph 2
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
Rut Latest fluid recommendations Spridgets 5
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
M Brake fluid on tire - cylinder need replaced? Spridgets 19
Z TR4/4A Diff Fluid - GL4 Triumph 7
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
B General MG Brake fluid MG 7
F TR2/3/3A Flushing Hydrulic Fluid Triumph 26
R TR2/3/3A TR-4A Gearbox Fluid Triumph 17
R TR2/3/3A Brake Fluid Triumph 6
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
R TR2/3/3A Transmission fluid for 57 TR-3 Manual OD Trans Triumph 3
Joe Schlosser BN1 Steering Box Fluid Austin Healey 13
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
Got_All_4 TR2/3/3A Push switch for washer fluid pump Triumph 4
L 100/6 BN4 Brake fluid Austin Healey 17
toysrrus TR6 Clutch fluid question Triumph 4
RandyInUtah TR2/3/3A TR3 gearbox fluid levelsI Triumph 4
M Losing Brake Fluid Austin Healey 8
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
J TR6 Wiper fluid bottle Triumph 2
P BRAKE FLUID CONTAINER for BT7 Austin Healey 0
P Front drum brakes - fluid lines Austin Healey 12
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
