Anybody know if you can still get floor repair panels for a Stag? I've looked and can't find any. Today I started to try and fix the rotted floors in a friend's Stag, and if today was any indication of what's to come, I'm in for a ton of work. Removed the seats and carpet only to find very rotted floors. From under the car, they didn't look so bad because of the liberal coating of spray on undercoating. Once the carpet was removed, you could see that the PO had installed sound deadening right over fiberglass that was covering up the rust. Only after chipping away all of the nasty, did the true extent of the rot reveal itself. It was bad --- MGB bad! Probably looking at 20 to 25 hours worth of fabricating and welding if I can't find panels. Also noticed why the front suspension seemed shot. Where the front left lower control arm mounts to the frame rail, there is extensive rust. I'll have to fabricate all of that as well.
Hi Guest!
