TR2/3/3A Floor Pan Crack
CI_TR3
Well, I pulled the seats out today to look at my floor pans for the first time (see pictures below). Any ideas on what to do about the cracks around the hole where the seat track mounts? What about the rest of the pan. Leave as is or try and put down some type of rust inhibitor like POR15. This is a survivor car so I am not doing a restoration or anything just trying to keep it in good shape and useable.
Thanks for the help.
Deleted member 8987
You're gonna get several options...from nothing to a full rotisserie restoration with new sheet metal.
But...what I would do it stop drill each crack. If you have a welder available, weld the cracks up. Grind off, paint (whatever you have) then gusset the hole.
I would at least spot weld a gusset on the inside to keep it from re-occuring....as opposed to underneath where someone might see it and question the gusset.
If you don't care, underneath works, too.
But whatever you do, stop-drill it now.
charleyf
I agree to stop drill the cracks and weld them. As your nut in a cage is underneath this hole you need to reinforce the floor here. Ideally it would be best to weld a patch on the underside after removing the nut and cage. Replacing the cage and nut is again ideal but you can avoid this by just placing a washer and nut under that bolt.
From the picture it looks like in picture one that the floor to frame bolt in the upper right also has a crack starting in the floor. Not a big concern but while you are dealing with the other hole --- and the snowball begins.
Good luck,
Charley
sp53
Yeh drill a 3/16 or so hole at the end of the rip/tear in the metal to stop the run and pop rivet or weld a small piece of metal maybe 6x6 inches or what fits for a re-enforcement and call it good and drive.
Vila
I found the same problem with my TR4 drivers side floor when I took the seat out at the beginning of my restoration.
I also stop drilled the ends of the cracks, welded the cracks and ground flat, then welded in large washers around the seat mounting holes to strengthen the area on both the drivers and passengers sides.
B How big is the floor pan drain hole? Spridgets 0
B BE floor pan welds aren't everywhere? Spridgets 2
F TR2/3/3A Floor pan question Triumph 16
B TR4/4A Floor pan replacement Triumph 4
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
T For Sale Triumph TR6 pass floor pan Triumph Classifieds 0
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
S TR4/4A Floor pan mountings Triumph 8
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
Zitch TR4/4A Floor pan replacement Triumph 18
S TR2/3/3A On installing the floor pan Triumph 4
bugedd Floor pan replacement Spridgets 12
A TR2/3/3A Floor pan measurement Triumph 1
M needed rt. ft. be floor pan Spridgets 1
Psevins TR2/3/3A TR3 Floor pan Triumph 22
P Interior - right floor pan Triumph 8
M Do you REALLY need drain holes in the floor pan? Spridgets 3
T Anyone used Moss front floor pan replacement panel Spridgets 2
B Holes for sets in BJ7 floor pan Austin Healey 2
Jim_Newman BN1 floor pan Austin Healey 6
W Floor pan comparison Spridgets 7
Stewart floor pan replacement MG 34
jjbunn Floor Pan Replacement Cost Triumph 10
S TR2/3/3A Tr3 floor pan removal Triumph 5
T What do you guys use to cut floor pan sheet metal? Triumph 7
T TR4/4A TR4A floor pan removal - easy or hard? Triumph 7
chicken Floor pan insulation panel Austin Healey 7
HAN8L1965 Replacement Floor Pan Spridgets 1
T Should floor pan be replaced? MG 15
bcbennett Floor pan replacement Triumph 4
F TR6 Rust and small hole on floor pan- TR6 Triumph 6
H MGB MGB floor pan question MG 4
svtmikey GT6 Floor Pan replacement [GT6] any helpful hints Triumph 1
A Rocker panel or floor pan first Triumph 1
C Floor Pan Replacement by Novice MG 2
aeronca65t Sill and Floor pan replacement MG 3
HealeyRick Perfect Healey Floor Jack Austin Healey 14
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
B Two questions about Bugeye floor panel weld drilling Spridgets 15
Healey Nut Insulating Floor Covering Austin Healey 7
B A plan to replace BE floor pans Spridgets 0
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
J TR2/3/3A Pads under new floor Triumph 7
F TR2/3/3A Boot floor Triumph 50
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
