The forward end of the floor panel on my TS 58023 as it attaches to the bulkhead kick panel is quite different than the joint on post 60k cars.
The kick panel on this on folds back under the floor where it is lapped and welded. Do you think this is correct on earlier cars or might it be a modification? On newer cars, the floor extends beyond the bulkhead bottom and the two are pinch welded forward of the actual joint. I'm curious since PO claimed that all the sheet metal is original.
Tom
TS 58023:
TS73117:
Tom
TS 58023:
TS73117:
