jtb55
I have a 100 M vintage race car with SU H6's. Having seen two failures in the banjo connector between the float bowls on two other race cars I made up a aeroquip an6 replacement I had seen other racers use. However after installing it the aft float bowl overflowed ( no problem with the front float bowl) so I took it apart and replaced gaskets on the float bowl and cap nut. It still overfowed. Because the ID of the old connector was smaller than the ID new aeroquip line I thought that this maybe the problem and reinstaled the original banjo connector and it still overflowed. So I took the forward float bowl apart to compare the two, they looked the same. I went to my spares (Joe Curto) and noticed that my spare float needles were metal whereas my existing were plastic. I tried to remove the old seat (brass) but was unable to get a wrench on the old seat ( threads into the bowl cover) Any ideas as to how to get them out ? Also do the bango bolts that attach the old connector to the float bolts need to be alligned with the connector ? I don't think it is necessary because connector seems to provide a machined path to allow adequate fuel flow. thanks jtb
Hi Guest!
