Andre the Giant
The saga continues. I've been battling this for a while now, but had to take a few weeks off from working on the MG to do basic household tasks like mowing, fixing things, etc. Now I'm ready to fix the problem.
The car idles fine, but when on acceleration, when the RPM reach 2,300 or so, the engine boggs down. To get the power to reach the next gear, I have to floor it. The power seems to pick up when its floored.
Here's what I've tried. (all of these have had little to no effect.) Replaced the carb diaphram (ZS carb), tinkered with the mixture, reworked the carbon canisters, tightened all vacuum/emissions hoses, installed new coil, dist cap, rotor, plug wires, plugs, checked the timing, checked the vacuum advance, (Its a CEI distributor, not an OPUS one) adjusted the clearance on the rocker arms, cleaned the carb including the fuel bowl, and checked the fuel pump and hoses.
My latest theories involve the auto-starter (choke) which I discovered has some stripped bolts, and the coil. The bolts that hold the heat mass/water jacket to the autostarter are stripped allowing the whole mess to rotate instead of staying in place and acting on the auto-starter lever. I have another auto-start assembly which I will install this weekend. A wise man on this board wrote that the Lucas Sport Coil isn't the right match for my ignition system. So I'm going to switch back to the stock one and see what happens.
If that doesn't solve the problem... I'll go absolutely bonkers!
Any other ideas?
[ 08-01-2003: Message edited by: Andre the Giant ]</p>
Any other ideas?
