Hi guys - hope everyone's week is off to a good start.
Now the weather is (finally) cooling off a bit I am running around in the TR4a shaking her down for regular use. One recurring issue I am dealing with is that the starter has what appears to be a flat/dead spot. Here is what is going on:
1) Battery fully charged
2) Good grounds and solenoid connections
3) Used gear reduction starter
4) Sometimes she cranks to beat the band, starter easily cranks the engine over and she catches right away
5) Sometimes it will do a 1/2 crank and then bog to a point where the engine doesn't spin at all
#5 suggests to my eyes suggests I've got a bad starter and it needs to be pulled to be rebuilt.
What do you think? Yes/no/other ideas?
