I am installing LED 1156 bulbs in the rear Turn Signal lights on my 1977 MGB. I found two flasher units in the area under the glove box. Both are Wagner. One is a 552 and the other is a 592. If someone has replaced these with electronic flasher units, what did you use? Are they the same and some previous owner just used what he could find to replace the original units?
Thanks,
Charlie
Thanks,
Charlie
