EastBoundJoe
Member
Took out the flasher relay of a 1972 Midget and started the car up let it run for ten minutes, then the next day she would not start. When I put the key in the ignition I couldn't even hear the fuel pump running. It seems that the battery is dead because all of the fuses are fine.
Maybe a short was made while fiddling around with the relay, I'm not sure but it seems really weird because I didn't leave any lights on to drain the battery.
Any input would be greatly appreciated.
