Fixing turn signals at head
bluemiata90
Is there a way to get into the head to fix or clean up the turn signal indicator contections. I think I've track the problem down to the head contectors. I have power going into the head from the flasher, but only have power coming out on one side (the wrong side) at the bottom of the stator. Is there a way to open the head at the steering wheel and adjust the connections.
TRopic6
My TR3 is stored on the mainland, but I remember there were three small "grub" screws that held the metal plate that held the turn signal head. Look on the steering wheel hub behind the spokes - they're countersunk into the hub.
You also have to loosen up the gland nut at the bottom of the steering box because the whole tube with the wires has to come out. Early 3s have a one-piece steering column and others have a split shaft. Maybe someone has done this job recently can describe it better.
Jeff
74 TR6 CF13816U
Honolulu, HI
DNK
Check the archives I thought this was a question a couple of months past. I think Don E. had the answer but don't count on my memory!
bluemiata90
bluemiata90
With some further research, I think I did find the answer. The head must be removed from the tube(car) and on the backside of the turn signal/horn unit, there are 3 flat head screws that must be removed to open the head unit. I do believe that I'm going to install a custom chrome turn signal switch with an indicator light built into the handle that I found on ebay, instead of removing the head and tube. The switch looks very nice in the pictures and would add to the interior looks of my TR3. I only hope I can get it to work correctly. I'll keep you posted
M Wedge tr7 turn signal switch fixing? Triumph 1
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
steveg TR6 Fixing the intake manifold Triumph 8
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Got_All_4 TR6 Is this head toast or worth fixing Triumph 3
S TR4/4A Fixing dash support Triumph 11
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
M BJ7 back panel fixing method Austin Healey 5
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
Jeepster Seat belt fixing Austin Healey 4
P BJ8 wing and panel fixing help? Austin Healey 3
Jeepster Front wing flash fixing holes Austin Healey 5
JamesWilson Fixing Fiberglass Flaws?? Restoration & Tools 9
T ideas on fixing - one carb keeps "rusting" Triumph 4
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
T Tips for locating/fixing foam rings under gas tank Triumph 4
T Ideas on fixing this? Triumph 19
regularman Found one problem while fixing another Spridgets 9
B Fixing crack in rubber bumper MG 1
bcliff Fixing a bad spot in the paint MG 3
germanmichel Fixing outer tube in steering box Austin Healey 11
G I my engine fixing to blow........................ Triumph 9
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
roscoe I'm fixing my overdrive with a saws-all Austin Healey 10
jhorton3 Fixing Things Spridgets 27
drooartz Leaking hubs, parts for fixing Spridgets 11
T Fixing Rust Triumph 16
69MGC Any tips for fixing a bent boot lid MG 7
cjm lightened flywheel,best fixing? Triumph 3
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
S Fixing Dime sized chip Triumph 3
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
B Will fixing Healey Shake negatively affect Resale? Austin Healey 6
Carlbanan56 MGB Mgb turn signals MG 17
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB help, turn signals do not work MG 3
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
bighealeysource Turn Signals Austin Healey 21
B General MG Turn Signal Issue MG 1
