Fixing Fiberglass Flaws??
My car's fiberglass body is showing blisters on the surface. When sanded down it looks like someone applied filler over the original surface and that caused a reaction with the gelcoat. Under the blisters the gel coat looks "crazed", like paint after paint stripper's been on it. See photo:
To fix this- Do I sand all the old filler and gel coat off, and use epoxy based resin with chopped strands and/or silica filler or tissue to repair the surface. Or what.At first I thought it was osmosis... but not now I see this....
TomMull
The first thing I'd do is try to determine whether what is left is stable. From whatI can see it appears as though the underlying laminate is solid. It also appears as though a considerable amount of fairing has been done in the past (Perhaps when it came out of the mold). A bit of sanding should show completely dry dust, nothing should stick together and nothing should flake off. If it seems solid, fill, fair and paint. Sand enough to provide a "tooth" for the filler. I would use an epoxy fairing compound with no glass fibers in it. That stuff is miserable to fair (it is usually harder than the surrounding gelcoat or filler). instead, lay a little piece of fiberglass cloth and unthickened resin in any deep holes that might need structural reinforcement. For fairing, epoxy with sanding filler mixed to peanut butter consistency works well for me. You can also buy pe-mixed filler.
I can't really see the crazing (cracks) from the picture but old gelcoats are prone to crazing and problems with the bond between the gel and the laminate. (Note that these cracks are in the gelcoat only. Cracks that go through the laminate must be cut out and patched.) Crazing can be easily covered with filler or even paint but the cracks tend to show through the surface after a short time and gradually worsen. The best fix is to remove the gelcoat completely then apply filler and paint but that is extremely time consuming. I find the faster methods of getcoat removal like peelers and media blasting too aggressive for thin car bodies. I compromise by sanding as much as I dare, cutting hollows into the bigger cracks, fill, fair, paint and then hope for the best.
Tom
JamesWilson
Thanks for that.I've used a Dremel tool with a cutter to grind the cracks out into "V"s and filled them with epoxy/silica filler that I've then sanded down. The plan was to deal with the dozens of cracks that were fairly common and widespread and then deal with the blisters.These blisters are only on the very front and left door, so I suspect there may be accident damage that was covered up with a thin coat of filler that reacted with the underlying fibergalss. So... all that old stuff will have to come off and an epoxy filler go on.I plan on using a heavy grit orbital sander to take it down to solid material and then build it up from that with the filler. I've got silica powder to mix up with the epoxy so that's do-able.
TomMull
Sounds like a good plan to me. However, I will repeat my pitch in favor of lightweight (marine?) fairing filler, at least for the final skim coat. While silica makes a very good filler material, it does not sand easily and you should not use polyester auto body filler over the epoxy. Tom
LarryK
Go to one of your Scottish boatyards, show them a picture and I'm sure they will fix you up quickly.
JPSmit
Nae! Haggis does nae stick tae fibreglas - nor oatmeal!
JamesWilson
So... an update on what I've done these past several months. I ground out all the cracks and filled them in with filler, sanded those smooth and fixed a few little body flaws. I then stripped all the gel coat from the front half of the body, both doors and the roof, down to the fiberglass itself. Then coated it with two coats of epoxy resin. I'm now in the process of smoothing the surfaces a panel at a time. Hope to finish for Christmas with it primed. Need to get it running again too, but that should be easy by comparison, charge the battery and re-install the fuel tanks...(but that's another story).
PAUL161
James, depending on how old the fiberglass is could determine just how long the repairs will last before hairline cracks start to reappear. The 1953 and 54 Corvettes fiberglass bodies were of a poor glass and after a few years would get hairline cracks all over, called cob webbing, because that's what they looked like. Many attempts were made over the years to repair these bodies, but the final solution was new aftermarket identical bodies were made from modern materials. They were so perfect that the Corvette club excepted them as original. What I'm trying to say is, don't be alarmed if in a couple years the hair lines start coming back, especially if the car is exposed to a lot of sun. Hopefully not! PJ
Redlacquer
I did the dreml out cracks, fill n paint on a mg hardtop a few years ago. Now there are new cracks. If I do it again I'll strip paint and sand off all the old gel and give it a coat of resin
somewhatspritely
In my experience if you really want to fix cracks you need new mat and tissue under the resin. It's a horrible job but the only way to a sound repair. Without new fibres things will flex and re-crack. I've previously used a disk sander to grind a shallow hollow. then layered in mat and tissue with new resin. The mat is strength and the tissue stops the strands from the mat showing in the final surface. Those repairs lasted over 10 years with no re-cracking of the problem areas.
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
steveg TR6 Fixing the intake manifold Triumph 8
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Got_All_4 TR6 Is this head toast or worth fixing Triumph 3
S TR4/4A Fixing dash support Triumph 11
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
M BJ7 back panel fixing method Austin Healey 5
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
Jeepster Seat belt fixing Austin Healey 4
P BJ8 wing and panel fixing help? Austin Healey 3
Jeepster Front wing flash fixing holes Austin Healey 5
T ideas on fixing - one carb keeps "rusting" Triumph 4
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
T Tips for locating/fixing foam rings under gas tank Triumph 4
T Ideas on fixing this? Triumph 19
regularman Found one problem while fixing another Spridgets 9
B Fixing crack in rubber bumper MG 1
bcliff Fixing a bad spot in the paint MG 3
germanmichel Fixing outer tube in steering box Austin Healey 11
G I my engine fixing to blow........................ Triumph 9
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
roscoe I'm fixing my overdrive with a saws-all Austin Healey 10
jhorton3 Fixing Things Spridgets 27
drooartz Leaking hubs, parts for fixing Spridgets 11
T Fixing Rust Triumph 16
bluemiata90 Fixing turn signals at head Triumph 3
69MGC Any tips for fixing a bent boot lid MG 7
cjm lightened flywheel,best fixing? Triumph 3
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
S Fixing Dime sized chip Triumph 3
M Wedge tr7 turn signal switch fixing? Triumph 1
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
B Will fixing Healey Shake negatively affect Resale? Austin Healey 6
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
R After market 3000 fiberglass hardtop Austin Healey 13
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
Editor_Reid Securing Bugeye Fiberglass Bonnet Spridgets 15
A TR4/4A Fiberglass Surrey Top question Triumph 3
BillyB62 TR2/3/3A TR3 Fiberglass hardtop Triumph 6
S TR2/3/3A green fiberglass fix it stuff Triumph 9
S TR2/3/3A fiberglass filler Triumph 4
RickB Any fiberglass one piece fronts available used or cheap? Spridgets 15
DanLewis New fiberglass Bugeye bonnet $395 [NFI] Spridgets 0
O Bugeye Fiberglass Hardtop FS Spridgets 0
P Fiberglass hardtop Triumph 0
