M
Mike_Bouse
Fuel gauge in the Spit reads 100% full all the time, regardless of fuel supply. a little disconcerting when you realize that i have zero driving experience with this vehicle, meaning no concept on range, mpg, or capacity.
The gauge isn't stuck. it pegs full when the key is on, and returns to zero when the key is off.
Should i think about repairing the sender, or is there little or no hope in making this repair myself?
is there a test i can perform to assure myself that it is the sender that is at fault, before i order a new unit? I have an old fiat sender that i could externally hook up to the leads...would that prove the issue?
