fitting turnbuckles on "62"
WALTER
Finally putting her back together after about 5 years. One mystery I've run into are the turnbuckles behind the doors. Why are the holes different sizes. What holds them on to the body? Shouldn't there be something between the turnbuckle and paint to protect the paint?
Thanks,
Walter
Re: fitting turnbuckles on "62"
Turnbuckle??
Not sure what you are referring to as "turnbuckles"??
Hah! Jack, you and I had to be posting at the same time!!! :laugh:
Great minds.
The turnbuckles are the 2 top fasteners behind each door. You know, the ones you turn to buckle the top down?
Anyway, they are held on with 2 #6 I think sheet metal screws. There wasn't anything beneath them to protect the paint, but if you fee so inclined, a bit of thin rubber would work. 2 different sized holes tells me one screw was oversized.
Peter
The ones on my car were riveted on!
OH, learned something.
Mine were riveted on.
I sit corrected..... looked at a BE in the shop just now... indeed, riveted.
Moss cat shows screws.
Sorry
Peter
Yes riveted but they always loosened up with rivets.
I have used #6 x 32 machine screws with a nyloc nut on the back side. They never move.
But getting to the inside to get the nuts on is no fun.
My wife gets that job because my fingers are too fat.
Buy a few extra nuts too, you will drop one or 2 trying to do this.
Now what's that rattle???? :devilgrin:
Thanks for clarifying things Peter. I have the screws that Moss sells(6 x something) but both front holes being smaller made me wonder.
Thanks all,
Walter
Someone probably drilled out the rear one making them larger!
