Fitting Damper bushings Question
sim
The old ones were in collars with a washer built on. The new ones will not fit onto the collars. So I guess the correct fitting should be to remove the collars add large washers on the out side and fit back into the top of the swivel pin.
holder. Ya on No?
Thanks
Sim
The collar that is butted up to the head of bolt must be removed. Install your bushings then and everything will fit as it should.
Hi
Thanks should I use thin washers or just install the bushing and nut?
Sim
I fitted washers . Didn't like the idea of nothing to prevent catastrophe except plastic!
