BJ8 Phase I
I replaced my braided hose piece between the front and rear carb because it had degraded and was leaking and in the troubleshooting process also replaced the braided hose between the steel fuel line and the front carb. What is the brass male fitting on the 5/16" steel fuel line that connects to the approx. 20" long stainless braided hose that connects to the banjo union on the front carb of the HD8 ( BJ8) carb. I bought a replacement braided hose from Moss. Moss says the 5/16" nut is BSP threads. I tightened up the nut on the new hose and I still have a very small leak. The old hose had a stainless cone with a stainless compression nut and the new hose has a stainless nut with what looks like a brass cone? I am thinking that I may have to replace the brass 5/16 " fitting on the steel fuel line. Moss doesn't sell the 5/16" fitting but sells the complete fuel line from the pump discharge to the engine bay with the 5/16" fitting at the end. Seems a bit too much just to replace a fitting. Is that 5/16" brass fitting simply soldered or is it brazed on and what is the fitting?
John B
John B
