Hi Guest!
Gearbox off centre... check and tighten each bolt or clutch pate misaligned.. again check bolts that retain the clutch plate.. faulty slave cylinder cheapest and simplest thing to change..
Why take the risk.. just change the clutch plate and be done with it..
Thanks British_Recovery - the grooves in the pressure plate are quite shallow but I think the best method would be to keep the current flywheel and find the appropriate bell.
I need a 3000 bell designed for the larger, 10 inch clutch and sideshift. Anyone have a spare lying around!?!
I didn't notice much more power from a lightened flywheel on my BJ7 engine, so I didn't lighten the one on my BJ8 engine, but on both engines is a BJ8 clutch attached to and balanced with the flywheel. This is absolutely essential or the engine will vibrate. The earlier flywheel needs drilling to suit the later clutch, but it does give a lighter pedal pressure and is more pleasant to use.
I replaced my clutch disk and pressure plate and now have a minor but annoying vibration at about 2000 rpm. I had a major vibration when I reinstalled the flywheel 90 degrees off. I was unaware of the need to have the number 1 stamped in the flywheel at top dead center. After learning of this requirement (on this forum), I removed the transmission after looking at the photos I had taken before and after and noticed the change in flywheel location. After correcting the flywheel location, the vibration was much less noticeable, but I recommend anyone replacing the clutch/pressure plate to have it balanced with the flywheel.
