trotti
I finally got all the brake issues resolved in my car and I'm on to tackling the next issue - an unfortunate "judder" or vibration when pulling away in first gear. It's much more pronounced when starting from a hill. As I begin to lift off the clutch, a slight judder begins that intensifies and gets quite dramatic. This happens both when the car is cold and after it has warmed up. Feeding it more gas doesn't help. It will start off fine in second gear without the vibration, but starting from second every time is not a good fix.
I've read everything from bad motor mounts (mine look to be in great shape), fouled plugs (just put in new Champions gapped at .025), low tire pressure (I'm 32 all around), bad carb setup and even bad pedal linkages causing this in other vehicles; seems like there are a variety of causes. I've bled the clutch slave cylinder and it appears to engage/disengage correctly. Shifting throughout the other gears is fine. There is an overdrive attached and it seems to work without a hitch.
Thoughts on what might be causing this?
