TR6 First drive in the TR6 went well...until it didn't
sammyb
I got all my TR6 project all buttoned up, the clutch hydraulics bled and decided to actually take it on its first shakedown on the road. First thing I noticed was that it was running very well despite having the head off, carbs off, etc... and it was shifting well -- and even the Overdrive was working like a champ. Speedo wasn't working, but given it came with a new cable, I figured it wouldn't work.
I decided to turn around about six blocks down the road and start heading back to my garage. About a block later...
...no engine power. It was firing a little, but just coughing.
When I went to neutral and revved it, it seemed to rev up. In gear under load it just crapped out. I was able to cough and sputter the rest of the way at about 10mph back to the garage. It would idle fine and rev in neutral. Managed to get it back into the garage under its own power after it stalled in the driveway.
My gut tells me something like a bad coil or condenser. (I replaced the condenser, but not the coil.) Seems to me that if it was fuel, it wouldn't make a difference if it was in gear or out of gear, right?
I did the typical ADD thing -- once in the garage, instead of troubleshooting, I decided to attack fixing the speedo cable and redoing the seats and carpet.
But if anyone has had this symptom happed to them in the past, I'm all ears about the source of the problem.
Thanks,
Sam
Darrell_Walker
Any chance the timing slipped for some reason?
S
sammyb
Here's another thought -- there oil pressure looked really good -- but maybe even too high. Could I have stuck the valves because oil wasn't flowing well through the rockers? Maybe I goofed putting the rocker shaft back in? I had to replace one broken rocker, so maybe I did something stupid?
I'm trying to figure out what might cause a problem once the car heats up -- that's why I was thinking electrical. My dad's 1929 Franklin had a problem that if the felt pads weren't oiled manually from time to time, the valves would stick, but usually worse under engine load.
Thoughts?
S
sammyb
Darrell,
Would the timing slip enable it to rev under no load, but not under load?
As I mentioned, when I got it back, it was revving fine in neutral.
TR3driver
Great Pumpkin - R.I.P
On the contrary, pulling under load (in gear) takes a lot more fuel than just revving the engine without a load on it. Sounds exactly like a fuel delivery problem to me. First thing I would do is either replace the fuel filter, or try bypassing it.
Ignition can also be load (and temperature) related. One way to distinguish them is to note what happens when you let off the throttle. If it immediately smooths out, it might be an ignition problem. But if it takes a beat or two and then starts running good, it's very likely fuel. The float bowls get drained when there isn't enough fuel delivered, and it takes a few strokes of the pump to fill them back up.
S
sammyb
My first thought was fuel, but then I went with the wrong assumption about load vs. no load and fuel consumption. I kept thinking "most fuel problems are ignition." I suppose fuel would be the easiest to deal with. I actually drained the tank and the lines about a month ago. If memory serves, there is no inline filter on it right now, which was a stupid oversight on my part not to put one in.
Thanks boys! I'll root through the fuel system again and see what I can find. I tell you, this car has made me feel dumber than a box of rusty tools. All my common sense mechanics and skill seem to fly out the window when I'm working on this thing!!!
bobh
Did you use a new gasket when you installed the valve cover?
In one of my TVRs I had a similar problem. The car ran great until the engine came up to temperature. Then it would barely run.
After a bunch of troubleshooting. I found the valve cover gasket was old, hard and saturated with oil. The oil was sticky when the engine was cold but became thinner as the temperature increased. The cork gasket was no longer flexible enough to seal the cover. Once the oil thinned the seal was broken.
I found the problem when I swapped out some SUs for the Strombergs. I connected the vacuum line where ever they would fit. After the engine warmed there was a loud sucking sound coming from the joint between the head and the valve cover. Basically a gigantic vacuum leak. Not exactly an application of The Scientific Method, but it did allow me to isolate the cause.
I run a Pertronics unit instead of points on my TR6. You may want to consider doing the same. Some people say they have had bad luck with these. Others say do not leave the ignition key on the run position of the engine is not running. They say this was the cause of theor Pertronix failure.
I've been using the sane unit for 8 years without problems. I do carry a spare pertronox and my points setup just in case.
Let us know when you find the problem.
BOBH
Fuel delivery would be my first place to look. Hopefully you have an original type fuel pump with the hand primer. If so, disconnect gas line at the carbs ( use a small can to catch gas) and operate the lever on the pump. You should be able to tell if you are getting plenty of gas. The last 3 or 4 TR6s I've bought that have been sitting for a while, the gas lines are clogged up with varnished gas. The lines will have to be replaced or cleaned out.
Marv
poolboy
I think I'd try flipping open the gas cap if it happened again.
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
N TR6 just bought a 74 TR6 with over drive..which size tires would be best Triumph 6
tr6nitjulius TR6 TR6/250 & Healeys Drive 'em! Triumph 0
N TR6 Bolt size for TR6 Drive shaft? Triumph 6
G TR6 Can finally drive the TR6 with a steering wheel Triumph 7
G TR6 My 1600 mile weekend drive for Ebay TR6. Triumph 12
B TR6 Saturday night at the drive-in with TR6 Triumph 10
T TR6 TR6 distributor removal - tips on tach drive Cable Triumph 5
B TR6 TR6 Drive Shaft Cover Triumph 7
Airfix TR6 TR6 "J" over drive install Triumph 15
G TR6 TR6 Vibration in Drive Train Triumph 4
M TR2/3/3A HVDA Speedometer Drive Triumph 10
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
B MGA Tach drive issue MG 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
3798j Off Topic MGB at the Drive in Bank MG 1
Popeye General Tech O/D right angle drive choices Triumph 10
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
AngliaGT Mixture of Cars on My Drive Today Spotted 8
drooartz MGB First drive of the year! MG 5
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
DocDup1 MGB SpeedBox Speedometer Drive MG 0
tr6nitjulius General TR All TRIUMPH Only Drive In 2022 Triumph 4
BritBite Speedometer Right Angle Drive Austin Healey 5
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AngliaGT On Today's Drive Spotted 0
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
Zitch Engine Oil Leak After Long Drive Austin Healey 19
D T-Series Shorrock supercharger drive belt MG 7
tr6nitjulius General TR Sir John Black Drive Your TRIUMPH Day 2/10/22 Triumph 0
D Off Topic Remember to drive your Triumph Triumph 3
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
R TR6 Drive shaft orientation Triumph 3
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
KVH General Tech Angle Drive Broke (Repost) Triumph 0
KVH General Tech Angle Drive Came Apart Triumph 10
R TR6 1973 Final drive issues Triumph 5
F 1954 MG TF for sale, ready to drive and show MG Classifieds 1
C Bugeye propeller/drive shaft- universal joint Spridgets 1
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
nichola TR6 Oil pump drive barely engages Triumph 2
T Angle Drive Lubrication Austin Healey 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
L TR2/3/3A Drive shaft question Triumph 5
Lin Tach drive housing for BT7 Austin Healey 4
4tecdog Speedo drive gear Spridgets 15
