Deleted member 8987
Been almost 4 years, runs good, decent mileage, all that.
Today, took it out for a spin, noticed it was bogging a bit. WOT, a bit of roar I wasn't used to.
Got worse.
On the way back from visiting the daughter and grand daughter, got real bad. Tried to come up the hill to home, normally pulls it in third, barely (20MPH)in second.
Did the normal..checked advances, points, rotor, cap. Dwell was 37, which is 35 + or - 2, so okay. Checked oil in air cleaner, clean.
Replaced fuel filter (always some rust), decided to balance the Solexes, as I knew they were out. Held throttle, set UniSyn on #1 carb, slipped it back to #2.....ball stayed on the bottom, Tried moving the ball up on #1, re-tried #2, nothing.
Hmmmm. Looked closely.....clamp from shaft to #2 carb had come loose. I was running on front carb all the way home.
Got 'em balanced, so we'll see if it's smoother!
Dave
Got worse.
Dave
explains that
