David_Doan
My firewall has A LOT of holes in it. I'm making a new wiring harness with the intent of simplifying wire routing and hiding as many wires as possible. Heater is gone, mechanical tach cable is gone. The hinges are also gone, so I can cover those holes as well. The raised areas just behind the battery have holes in them as well, so I cut those out to make it flush. I want to cover the firewall with aluminum, I need apiece about 6" x 50", 1/8 to 1/4 thick.
I'm having a hard time finding something locally, ordering anything is at least $50 with shipping. I'm curious if anyone else has done the same/similar?
I looked at diamond plate as well, it is also expensive. The only thing I found in Lowe's/HD was metal flashing for roofing, but it is too thin.
I saw this done on a Big Healey, but I can no longer find the pic.
Hi Guest!
