V
vagt6
I have a bit of a challenge on my recently purchased '74 MKIII Midget and I'd appreciate input from you 1275 gurus out there on how to fine tune the engine.
The engine appears to be in very good shape (it's sure is clean!), rebuilt approximately 8K miles/5 years ago. It has roller rockers; upgraded cam; Pertronix; HS2s rebuilt; Datsun starter; head ported/polished; oil cooler; Haynes electric fan, and more. It does not smoke, leak, etc., and runs well.
I have documentation for all of this work, but not the cam, only that it's not stock (I've asked the P.O., he couldn't help as he's not the "mechanical type"). As such, I'm not sure where to set the valve lash. Thankfully, it's in good tune now so I'll probably see what the valve clearances are now and stick with those settings for the time being.
I'd like to assume that if it's a street cam (it idles at about 1050 RPM - below that it's choppy) the lash may be something like .014 on intake and maybe .016ish exhaust (this is inferred from APT and Piper websites for their popular street cams), but who knows? I'm pulling the valve cover this weekend to do a bit of exploring in there.
Reading the plugs, they look pretty good. The old plugs were moderately carbon fouled so I backed off the jet adjusting nuts a couple of flats and the newly installed plugs with about 100 miles look much better. The plug ground straps look a little burned (no color deliniation line on the strap) and the porcelain is snow white - no metal spots).
New car (to me), I don't want to assume anything. What do you think? How would you proceed? The valve lash must be adjusted someday, what to do?
Thanks for all the help.
Hi Guest!
