How do you guys turn the crank in your TR3 whilst searching for TDC in order to do the valve clearances?
I have a remote start switch so can use the starter motor but that isn't real precise. I would like to be able to turn the crank by hand but
even with all the plugs removed i can't get enough torque on the radiator fan to turn it over.
Alas, no hole in the radiator for a hand crank
Thanks for your input
