Finally had a chance to make some progress on my "winter" MGB projects. Yesterday was warm enough that I was able to get the floors repainted. They had a bit of surface rust here and there (the floors were replaced at some point in the past) but the biggest problem was that the paint was failing in places, coming off in big sheets. Picked up one of the POR15 starter kits and went through the process.
Had enough paint to do a single brushed coat -- it's probably a bit thin, but it'll do. May top-coat it with something else in the future, but it's way better than it was. Process was easy enough, just follow the directions.
Before:
After:
Black's not my first choice, but they don't make a white. It'll be covered with carpet anyways so I'm not too fussed. Good enough for floors at any rate. I'll give it a couple days to cure then it will be time to get the interior bits installed.
Before:
After:
