regularman
I put two coats of redcoat inside after cleaning it out good and cutting a hole to remove the strainer and clean the tank out good. I made two metal plates and used 32 small stainless steel screws to seal off the hole that I made. I then coated the top of the tank with Por-15 and its drying. I hooked up the gauge and calibrated it with the adjustment on the back. here is a photo of the fnished tank before painting.
