TR2/3/3A Final drive ratio for TR 3A
Tinkerman
From what I have read the TR2 through 3A had a final drive ratio of 3.7:1 and the TR4 through 4A had either 3.7:1 or 4.1:1 short of counting the amount of teeth on the crown wheel and the pinion gear, how do I determine the final drive ratio for my car?
The diff was rebuilt but I don't remember that we replaced the pinion or the crown wheel. We just replaced the bearings and seals. Had to do some machining on the differential casing. Since we didn't replace the crown wheel or the pinion gear it should be the same ratio, Right?
Any thoughts would be appreciated.
Tinkerman
martx-5
The ratio represents how many turns of the input shaft it takes to turn the output shaft one revolution.
In other words, how many revolutions of the driveshaft it takes to make the rear wheel go around once.
You most likely have the original 3.7 that went in most of the TR3s. BTW, you can't change just the pinion or the crown wheel, as they come as a matched set.
TR3driver
Great Pumpkin - R.I.P
Even the later TR2-3B were available with different ratios from the factory. The 4.1 was listed as an option; but others could be had by special order.
However, it appears that very few cars were so equipped by the factory. TS39781LO is the only one I've ever seen that had the 4.1 from the factory (as evidenced by the speedometer calibration); although it's more common as a later (even dealer installed) modification. TS13571L had 4.1 gears when it came to me, as did the first TR3A I ever saw (which my Dad now owns).
There are various ways to check; the easiest method depends a bit on circumstances. If the car is mobile, you can remove the plug in the driveshaft tunnel and make marks on both the U-joint under one edge of the hole and one wheel next to the ground (so the mark is vertical). Drive forward slowly while watching the mark on the U-joint until it makes exactly 4 (or 8) turns; then look at the wheel to see how far it turned. If the wheel went more than 1 (or 2) full revolution, you've got a 3.7 (or perhaps 3.45); if it went less than 1 full turn, you've got a 4.1 (or possibly 4.55).
Personally, I think the 4.1 gears are a waste on the street behind a stock engine, even with the (mandatory) overdrive. In first gear, the engine wastes a significant portion of it's torque just accelerating the crankshaft and flywheel. In fact, Steve Hedke reported that Scrappy's acceleration times actually improved on switching from 3.7 to 3.45 gears (which I also plan to do with TS13581L).
Tinkerman
Tinkerman
Thanks Randall, as usual you cleared that up for me. I will check that tomorrow. I suspect that it is a 3.7:1 bt wanted to check.
Thanks, Tinkerman
M_Pied_Lourd
TS 69891LO Came Stock with the 4:11 as well along with competition springs.
Cheers,
M. Pied Lourd
Geo Hahn
Remember that if you do the 'count the turns' method with the car immobile and one wheel on the ground, one off -- then the number of turns the moving wheel makes is double what it would be with the car on the ground.
At least I think that's true.
TR3driver
It is. Unless of course you've got a limited slip or welded differential
Tinkerman
Tinkerman
Randall I checked it with wheel rotation and it comes out to 3.7 which is very good because the speedo I have is calibrated for a 3.7.
Another little chunk in place.
Tinkerman
R TR6 1973 Final drive issues Triumph 5
ncbugeye What tool to remove final drive filler plug? Spridgets 12
ncbugeye Final drive on Bugeye Spridgets 17
M Rear axle [final drive] tools or information Restoration & Tools 5
A E-Type rear suspension/final drive continued.... Jaguar 4
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
Bayless Ready for final block sanding Spridgets 5
pbraun Bug i nearing final completion Spridgets 11
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
J Final painting detail questions Austin Healey 16
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
DornTRoriginal TR2/3/3A Final Check Items Restoration nearing completion Triumph 9
MadMarx TR4/4A [VIDEO] NĂĽrburgring RGB Seasons final race Triumph 12
dougie SOVREN Fall Final PRW Racing 2
B Final MARRS race of the season - free admission Racing 0
Pythias 1275 Transplant --- Final Report Spridgets 4
Jim_Gruber Bugsy's Final Goodbye Spridgets 4
KVH Final Testing of OD Triumph 2
glemon Final Rocker Shaft Question Triumph 5
F Final touches- a few detail questions for a BJ7 Austin Healey 11
hondo402000 Stag TR6 Engine rebuild in final stage, dyno date 7=22 Triumph 23
PAUL161 MGA Doc, Do You Know MGAs final gear ratio? MG 11
hondo402000 TR6 TR6 Final Paint pics and Putting it back together Triumph 31
drooartz Progress: garage space and the final list Spridgets 3
MadMarx [Video] RGB Seasons Final Nurburgring GP Track Racing 7
mikecyc72usa The final push Triumph 0
dougie HMSA Portland Historics 2009 Group # 7 Final Racing 4
zimmy 74 midget..............final price drop! Spridgets 7
SilentUnicorn The final straw Spridgets 26
reinaldo Stag Final stage in the restoration of my TR4A Triumph 23
Brosky Under windshield frame and final prep for paint Triumph 6
Brosky Final panel fitting & new mirrors Triumph 38
PATR8 Wedge TR8 repair mostly final tally Triumph 40
Brosky New Engine, the final chapter Triumph 3
Glen_B My final Ozark slide show Spridgets 1
regularman Well, just placed a final [hopefully] order Spridgets 8
JPSmit final question [tonight] - cleaning transmission Spridgets 5
bcliff Stuck Intake Valves.. The Final Chapter! MG 4
B Final Exhaust pics Spridgets 26
J Weber final adjustments-I hope Spridgets 2
T Final Timing Question [I hope] Triumph 10
billspohn Final Jamaican Pictures MG 22
regularman Can anyone tell me what the exact final ratio is.. Spridgets 15
jollyroger Sprite Parts Vortex final closing deals. Spridgets 0
David_K **Final Interior Combo Choice** Austin Healey 39
Simon TR4a Final cleaning before paint. Restoration & Tools 3
J MG plays its final act..[its sad and final] MG 3
Bruce Bowker eBay B - final price? MG 18
