Tinkerman
From what I have read the TR2 through 3A had a final drive ratio of 3.7:1 and the TR4 through 4A had either 3.7:1 or 4.1:1 short of counting the amount of teeth on the crown wheel and the pinion gear, how do I determine the final drive ratio for my car?
The diff was rebuilt but I don't remember that we replaced the pinion or the crown wheel. We just replaced the bearings and seals. Had to do some machining on the differential casing. Since we didn't replace the crown wheel or the pinion gear it should be the same ratio, Right?
Any thoughts would be appreciated.
Tinkerman
Tinkerman
