twas_brillig
Apologies for starting a new thread on this topic...
My rack hasn't been lubed since I bought it in about 1972; I pulled the oil fitting and its mounting (metric sockets seemed to work best in my case)and found grease.
The original BE shop manual advises to add "10 fluid ounces (0.28 litres approx.)" after rebuilding (ie when it is completely dry and empty).
Questions:
1 - has anyone ever tried filling by removing the hexagonal bolt just above the oil fitting?
2 - if so, does the 0.28 litre volume fill the rack such that removing the oil fitting and its mounting plug could allow it to function as the overflow point?
3 - and if I want to drain the rack, I assume that the only way is to break the gaiter seals? which haven't been disturbed since 1960?
Thanks,
Doug
Questions:
Thanks,
Doug
